2013 19er front jacks
Leo j
My pre owned 19er has electric front stablizer jacks. It seems to have no manual back up system incase of an electrical system  problem. Am I missing something or is this all there is. If a motor goes out, what are my options?
 Thanks for any help
   Leo J
jpalm
Manual backup
Leo - with your 19 should have come a hand crank to raise/lower the legs (it inserts in the circular plate with the dark center in the picture here.  If you didn't get one, perhaps you could order from Scamp?
Electric LG
Leo
It's been a while since I owned my 5er with a LG motor. I think you can still use your manual crank. The manual crank and motor are both connected to the same shaft, one on each end. You will just have the added resistance of turning the geared motor. Don't operate the motor with the crank handle inserted.
http://www.atwoodmobile.com/manuals/chassis/MPD%2071125%20SP%203.14.08.pdf
