Higher trailer clearance for mild off road travel.
egghed1
Last seen: 10 years 9 hours ago
I own a 1989 Scamp 19 deluxe and wanted to figure out what the best way to gain better clearance under the trailer. I was thinking about the tallest/ largest radius size tire that will fit after installing a 4 inch lift..I may have to get the down angle of the axel changed along with a four inch lift kit on frame to allow higher clearance and a larger tire. If anyone has a good solution for this I'd greatly appreciate it.
piperjim
You've probably already
You've probably already thought of this, but you may also need to modify the Scamp hitch, otherwise it'll be "running downhill" when towing.  Or, maybe that won't be a problem, depending on how your TV is set up.  I had my hitch changed when the Scamp was raised 4".
Good luck
