pre purchase questions
Ruralredhead
Last seen: 10 years 8 months ago
Greetings Friends,
I am looking to buy a used 13' Scamp to travel with my two small children.  What would be your top questions to ask a seller to determine condition? What are red flags to be aware of? Thanks in advance for sharing your knowledge.
Scamper Campers
Questions and Issues
Check and make sure that all of the appliances work.  Look for signs of moisture damage on the inside of the camper.  Look underneath the camper, there shouldn't be holes rusted though the frame and rusty scaly areas, the underside of the floor should be firm and solid.  Check for rot around the fresh water tank, it's under the passenger side rear bench.  Pay attention to the tire condition all three of them.  Hook the trailer up to a tow vehicle make sure all the lights and turn signals work.
Well, that is a start.
BobH.
Last seen: 8 hours 12 sec ago
Expensive Item
Following is the way I approach it and others may have different skills and be able to do some repair items that I won't. I evaluate a used molded fiberglass trailer by cost of what is needed. When those items are added to the purchase price and it exceeds the price of one in top condition then I keep looking.
The high dollar items are:
Axle replacement, appliances, foam and upholstery, tires and rims, structural and frame issues.
Shell condition(including windows) must be damage free and still be able to be polished back into good condition. Sub flooring is not a huge expense, but is high labor and I personally don't buy trailers that need sub floor work. Some folks don't mind sub floor repairs, just depends.
Electrical, plumbing, adding missing features, new vinyl flooring, painting or cleaning hide/rat fur, polishing shell, and needing top to bottom scrubbing are all items assumed to be needed and I don't worry about those because they're low dollar and almost all labor.
As you look, feel free to ask specific question on trailers you find, or any additional general questions you may have. Season ramps up in about 6 weeks and there will be quite a few for sale soon.
Jaye580
Jaye580's picture
The door
Don't forget to examine the door and make sure it closes good and tight. They tend to become dislodged and gap at the bottom.
http://jayes2scamps.shutterfly.com
Previous eggs:
198? 13' Casita
1984 13' Scamp (layout 1)
Current eggs
1978 13' Scamp (layout 1)
2016 13' Scamp (layout 2)
