Electric Tongue Jack
Marcy on the Move
Marcy on the Move's picture
On my recent trip I didn't crank my tongue jack up fully and bent it.  Once it was bent it hit the ground when I went up inclines.  Bad went to worse and I need a new tongue jack.  I have a 13 foot scamp and thought I might invest in an electric tongue jack.  Does anyone have suggestion of a good one that will work on my 13 footer?
Last seen: 9 hours 28 sec ago
Jack
After scraping my knuckles many times on the propane tank straps while cranking our 13 Scamp I put on a Barker VIP RV Power Jack
A bit on the upper end of the pricing and specs for a 13 Scamp, but that jack got transferred over to 2 more trailers over a decade before I finally sold it on our Escape 17B recently. Once you go electric tongue jack you never go back!  yes
kilovictor
kilovictor's picture
Last seen: 6 months 5 days ago
The Ultimate Trailer Jack
Check out the ultimate trailer jack. You can see it at Tractor supply. I like it because after I'm hooked up I can drop it quickly and get in the tail gate of my truck.
theultimatejack.com
EZ to replace your a-frame jack.
K
Marcy on the Move
Thanks & A Question
Thanks for the suggestions.  The Ultimate Jack looks like a great option because there is so much less cranking required.  However, the power jack sounds great because there is no cranking required.  I have a question about the Barker jack.  My current jack is only 7" from the bottom of the tongue and the Barker jack is around 9".  Won't that drag when I go up inclines?
