window leak
marvel
window leak
Hi, we have a 2008 13 feet Scamp since last year. We are having a problem with the over the counter window that leaks. Has anyone had a similar problem and how did you correct it? Have a great day! Danielle & Guy
Last seen: 1 year 3 weeks ago
Window Leak
There is a seal between the window frame and the glass frame. Make sure the seal is still glued in and intact. Clean and lube it with silicone paste. Or the frame to shell seal may be bad. If it is you will have to pull and reseal the window. Check first with a water hose to see where the water is coming into the trailer. If the glass seat seal is bad you will see the water coming in around the glass opening within the frame.
