Wheel Bearing Races stamped or replaceable?
Im confused.. are the bearing races for a Scamp 16 Std 3500 lbs axle replacable or are they permentaly stamped in place?
Last seen: 1 week 1 day ago
Bearing Races
They're replaceable.
Scamp parts shows them available to order: http://www.scamptrailers.com/parts-store-cat-view/running-gear/l68111-ra...
Thanks.. I read something
Thanks.. I read something about some hubs with the # 84 Spindle having fixed / permanent races.
Bearings
Hadn't heard anything about that one and Scamp Trailers only mentions going from a 1" to a 1 1/16" Spindle in the later years.
Are you looking for a Scamp 16? I see your profile still shows that you're looking and don't have a Scamp yet. Where are you at on getting a molded fiberglass and what models are you considering.
Scamp 16 Std Layout 4 on
Scamp 16 Std Layout 4 on order - expected egg-drop date of 21 Sep.
Just working on my toolbox now, and adding the bearings, races and seals so I do not get stranded on the 1,100 return trip.
Congratulations
Awesome.
Let us know if you find out the races are stamped now. I'm still showing races in the #84 spindle bearing kits, but one never knows if they've changed. I understand they have modified the black tank valves that were falling off, and the trailers now are being manufactured with the redesign. You'll enjoy that trailer and layout a lot.
To be clear, what I read
To be clear, what I read about the races was not specific to (nor did it mention) Scamp.. so I am sure you are right.  I did see one post that said Scamp was not using Dexter axles now, but some other brand whose name escapes me.  Not sure if that is right or not.
"stamped" vs. replaceable
By "stamped" do you mean press fitted to the axle so a puller might have to be used to get the races off?
