Drop leaf counter extension
debstaines
debstaines's picture
Last seen: 1 year 5 days ago
​Who has enough counter space in their Scamp 13? I do now :) used a bit of scrap Bamboo flooring from my cabinet doors project to build this little beauty
JerryJohn
JerryJohn's picture
Looks great, I was planning to do the same mod for my Microwave to set on, but then I couldn't use the flip up bunk which we need for stuff.  Which hinges did you use? I see the fridge is out, are you changing that also? or just access for the hinge.
Jerry Johnson
debstaines
Drop leaf
Hi Jerry
I ordered these hinges from Amazon, RV Designer H505 Folding Shelf Bracket, (Pack of 2) (picture below)
The ice box was out for 2 reason. The Scamp was about to go to Camping World for a refrigerator install and I took the opportunity to remove it myself so I could hang the hinges with wood on the inside for strength. The hinges support up to 100 pounds, but not that fiberglass. I screwed them in with some 3/4 plywood on the inside of the cabinet
finished fridge pic also below, made a custom panel out of the same bamboo flooring I used for the cabinet doors and that drop leaf.
Deb Staines
2016 16’, layout 4
'Rapscallion'
Nicely done...both the shelf
Nicely done...both the shelf and the refer!
