Advice on floor repair and glassing it in
pferraro
Last seen: 6 months 4 days ago
At some point I will need to replace at least a section of the OSB floor at the rear of a 2003 Scamp 13.
Anyone ever use HDPE sheets for this?
Is there any site that has a process for adhering it to the camper shell?  The tab or plat around the bottom om the shell appears to be quite flimsy. Would I just use sections of fiberglass above and below the floor to adhere the shell to floor in that area?
pferraro
Door repair
Well, as I kept looking, I found the attached file(s)  I merged them into one PDF.  I am NOT the author.  It was posted by Robert Johans back in October of 2009!
I've uploaded the file: scampdoorrepair.pdf
