new door lock on 16': anybody install a keyless remote entry lock?
JBR
JBR's picture
The handle and lock on our 2017 16' model has served adequately since day one, but it's getting tired with wear. Thinking of upgrading to a keyless/keypad entry type. Anybody have any thoughts or suggestions? The one thing I'm wondering is door thickness. The ones I've looked at on Amazon seem to need a thicker door width.
thanks
Last seen: 11 hours 50 sec ago
RVLock
RVlock is one of the best out there in keyless. Two issues with molded glass trailers are whether there is enough flat surface at the lock location to fit one of these. The other would be to verify the door thickness as you noted. A call to RVLock probably could answer both questions. I have have curvature on my Escape door that I've never been able to fit a keyless.
JBR
JBR's picture
Thanks for that, Greg. Not
Thanks for that, Greg. Not sure I really need a swap-out, but a friend showed me his new lock on his stick trailer, and I liked the concept. Door thickness seems to be the main question.
Jonathan Rockey
vincentimes.69
Last seen: 1 year 2 weeks ago
Most cheap electronic keyless
Most cheap electronic keyless locks are built for inside use (not waterproof). Are you thinking going mechanical lock? For example "Lockey 3210".
2001-16' Scamp
