Replacement Battery
Tom in NM
Last seen: 2 weeks 21 hours ago
Replacement Battery
It's time to replace my battery. 202113'
I've looked through various threads but don't see any very recent ones. Hence this question.
My camping this far has always included power but I'd like to do some modest boondocking 2-3 days. Needs would be LED lights, Maxx fan in warmer weather and fan on the heater in colder nights. I don't do winter camping but in the mountains, nights can get cold even in warmer weather.
I have a group 27 battery now. I've checked and the converter does not support lithium.
I'm looking at a couple of 100ah AGM batteries and trying to figure out why some cost so much more than others.
Here are a couple on Amazon
https://amzn.to/3X5MZIQ
https://amzn.to/4do7Kp8
Thoughts?
Tom
Online
Last seen: 12 min 23 sec ago
Battery
I'm totally a fan of Lithium and have had twin 100ah Battleborns, solar, inverter for 5 years now. Lowest I've ever been was 60% and they can go all the way down. We boondock all the time for weeks and months at a time and only have to come in for tanks and propane. It's been in on our RV pad at our house for over a month now, never plugged in, and it's still at 100% daily.
I'd definitely look at AGM's over the standard marine battery, but Lithium's are the best and I'm covered for 10 years with Battleborn. I think they may go much longer.
Tom in NM
Lithium and Converter
Thanks. I do appreciate the advantages of lithium, but as I noted, I would then also need to change the converter. We're not interested (at least for now) in extended off grid camping. I'm hoping a 100ah battery would enable us to do 2-3 days. Do you think that's reasonable?
Tom
Online
Sufficient for 2-3 days
I use to be able to go 3-4 days on Group 27 deep cycle Walmart battery. Added a portable 50w solar panel that I would alligator clip to the battery and could go weeks if the weather was good.
You'd be more than fine for 2-3 days with almost any type battery and simply add a portable solar panel if you want to go longer.
Just a thought, you probably don't need to change out a converter to go Lithium. My converter was an older progressive and did not handle Lithium profile. Called Randy at Best Converter and he said I only needed to change out the charge module in the converter for much less, simple swap out and I then had the Lithium profile.
ashscamper
Not OP but ty
This was really useful and I'd not heard of the battleborn batteries, very happy to see they have a cold-weather version, have you any expereince with the self-heated kind?
Online
Heated Lithium
Basically, Lithium batteries will not accept a charge usually below about 25degrees. However, the batteries are fully functional down to like 10 below. So in the past, if you were running winter freezing temps you put heat pads under the batteries to accommodate charging. Now Battleborn offers a battery choice with built in heating.
I don't run in those kinds of temps except briefly and have never had an issue or needed heated batteries. Scamps aren't built or rated for cold weather so really shouldn't be needed for any Scamp application.
Hope that helps.
ashscamper
Cold Weather Scampin
Being in Maine that's pretty much 6mos of the year for us! I knew that they aren't insulated for cold camping, but when you say they aren't built for it, is there something to be aware of with cold scamping (other than the normal concerns for people with tanks)?
Tom in NM
Lithium converter
That's really interesting re upgrading the converter. Kudos for finding that out. I'll keep that in mind.
