Caulk for bench
Dhai
Caulk for bench
I am reinstalling my benches and want to know what is the best caulk to fill in any gaps along the floor? I want to be sure I can easily remove my benches if need be.
TIA
Diann
Last seen: 2 days 20 hours ago
Benches
I always used 3/4 Round trim at the base of the benches. Looked much nicer than caulk with wood plank flooring or linoleum and easy to pull the benches. If you want to use caulk then stay away from silicone caulk on fiberglass trailers, and use 3m 5200 or similar.
Dhai
That's a great idea, I'll
That's a great idea, I'll probably use it. I do have a concern about crumbs finding a way under the benches. Maybe a very thin bit of weather stripping foam attached to bottom of  the trim? My grands can get dirty in a bathtub. Thank you for your inspiration.
