Tongue Mounted Bike Rack - Options - anybody use the Jack-it 2?
14 posts / 0 new
ebrunner
ebrunner's picture
After reading the tales of caution posted in this and other forums regarding hitch mounted bike racks extending off the end of travel trailers, I've determined that as a newbie, I'm not going to take the risk with our 16' Scamp (2020).  Which puts me in a quandary as I need a way to transport 2 bikes.  I'm trying to see if any of the tongue mount racks are an option.  The Arvika looks great, but with the limited available frame space I don't see any way to successfully attach it.  The Jack-it 2 (Lippert) looks more promising, but I'm concerned about the space  available between its rack location and the front of the Scamp.  Has anyone successfully installed and used the Jack-it 2 with a Scamp to transport 2 adult sized bikes?  If so, any cautions?
Ditchrider
Ditchrider's picture
Bike Rack
I use the Jack-It rack on an Escape 21 and like it a lot, but I've never tried it on the Scamp.  I just went out and measured and it would be a tight fit on the Scamp I think.  If your TV is a pickup truck you could probably turn the Jack-It around and carry the bikes over the bed of the truck.  Somewhere along the road I'm pretty sure I've seen a Scamp with a Stromberg Carlson tongue mount rack so that might be a possibility for you.  I sure like carrying the bikes on the tongue rather than behind the trailer.  I can see them, they get a smooth ride, and they stay a lot cleaner.
Eric
ebrunner
ebrunner's picture
Good advice and thoughts.  I
Good advice and thoughts.  I think the Jack-it probably is too tight faced as designed (back) on the Scamp.  Your measuring provides some more confirmation.  I am hoping that someone has installed the Jack-it on a Scamp and could verify for sure one way or the other.  I hadn't thought of turning the angle to the front (my TV is a 2020 Ford Ranger) to ride over the pickup bed.  I'll look into that.  Thanks
Ed and Mary Alice
Ditchrider
Bike Rack
After looking at both trailers side-by-side in daylight I think the Jack-It would probably work after all as the upper part of the Scamp slopes back more than the Escape.  If you go to Fiberglass RV and do a search for "Casita Front Mounted Bike Rack" you will find some photos of tongue mounted racks on both Casita and Scamp.  If I wanted to carry bikes on my Scamp I would look closely at the Stromberg Carlson CC-275 combined with a Go Aero V2.
Eric
Larrywk
Larrywk's picture
Last seen: 2 days 12 hours ago
Bike rack
I signed up for the scamp forum membership so I could comment on this post. I purchased a 2018 Scamp new with receiver hitch . I had trailer sway issues with the bikes in the back. I don't use a equalizer hitch. Just the Scamp tongue on hitch ball. I purchased the Jack it bike rack directly from the manufacturer. I purchased the short tower. Most of the ones for sale on the internet are the taller tower. I had to replace the jack that the Scamp came with because the handle is on the top. I purchased a jack with the front mounted crank handle. I put to adult bikes on the jack it with no problems on my 16 foot Scamp with dual propane. The difference is tremendous. The scamp towes perfectly now with no trailer sway issues. I had to use the electric brakes to get the Scamp back under control after a bad sway event with the bikes on the back going about 65.  Had to slow down to almost 40 to stop the sway event. I will try to upload pictures if I can figure it out.
ebrunner
ebrunner's picture
Bike Rack
Thanks for the advice.  I will certainly look into those options and the Casita posting.  I've also been looking at a Yakima roof rack as a fall back (I already have bike mounts from 25 years ago).  I'm getting a little old for putting bikes on high (Ranger with 18" wheels) roofs, so I'm hoping a tongue mounted rack will work.
Ed and Mary Alice
Ditchrider
Bike Rack
Thanks Larry for joining the forum and sharing your experiences.  I have the taller tower and wish I had the shorter 18.5" one.  If I decide to carry bikes on the Scamp I will get a shorter one for sure.  Have you had any difficulty loading the bike that is closest to the trailer?
Eric
Larrywk
Larrywk's picture
No I am able to get both
No I am able to get both bikes up by myself but it is definitely a lot easier when my wife helps me.
It did take quite a while to figure out how to position the bikes on the rack. After I figured out where to position the brackets I labeled each one so I can reassemble it the same way and took pictures so I put the bikes up in the same position every time.
Also I remove the bike pedals on both bikes before I put them up. This makes it a lot easier to get them up and down and in to position.
I still have the old bike rack mounted on the back of the Scamp in the receiver hitch when traveling. I just don't put any bikes on it. When I get to the campground and unhook the Scamp I move the bike rack from the back of the Scamp to the tow vehicle.
ebrunner
ebrunner's picture
Bike Rack - Jack-it
Thanks for the information.  As luck would have it, I missed your post because we were out camping in our Scamp when you posted.  :)  .   Whilst camping, I did see some Jack-it racks mounted on non-Scamp trailers and got to talking and measuring; convinced myself it would work, but wondering if I'd need to remove the pedals.  Ordered the 22.5" tower from eTrailers when I got back... they had both, but the 18.5" was $100 more (go figure), so I decided 4" wasn't going to be a big issue.  Glad to hear this is going to work and everything pulls well.  The custom solutions that are out there look great, but I have zero welding skill, so this commercial option is attractive.  I also ordered a "bump-it" for about $50;  It basically is a metal arm that attaches to a hitch receiver and allows you to connect the Jack-it top, effectively turning the Jack-it into a hitch mounted bike rack.  I'll post more when I get it, but at least in theory it obviates the need to carry another rack.
Ed and Mary Alice
Larrywk
Larrywk's picture
I wasn't aware of the bump it
I wasn't aware of the bump it. That looks like a good addition. Reduced weight and space  versus bringing  the yakima carrier. I ordered the jack it directly from the manufacturer and they sold me the short tower for same price as etrailer and Amazon were selling the taller tower for.
Ditchrider
Jack-It Bike Rack
Like Larry, I used to carry a conventional bike rack to use on the TV when we left the trailer in camp, but recently bought the Bump-It bar so that I can use the Jack-It rack on the TV.  As Larry mentioned, it takes some trial & error to get the rack set up for your bikes.  Also, it will take some practice before you can load the bikes gracefully.  You wouldn't want to practice in a campground with lots of other campers watching.  Might not even want your neighbors watching.  I'm 74 and still loading the bikes OK.
Eric
