fridge
Rhalford
Last seen: 1 year 2 weeks ago
fridge
operating my fridge on 12 volt setting for a 2 hour drive and when i got there the fridge wasnt cold at all  back of fridge was hot just like it always is when its set to 110 watts  plenty of juice running into the battery on my scamp from my truck battery  any thoughts
I presume
I presume the fridge works properly on LP and 110/Shore power. It is difficult to determine what hot means to accurately  work out if it is hot enough. The principal of operation is the heating of the Boiler portion high enough to boil and separate the different chemicals inside the system, It can be hot to touch yet not make high enough temperature to boil . Actual voltage measured with a meter will be needed . Was it connected to the tow vehicle and a good charge wire  while on the 12 volt. or just on the trailer/house battery and was that well charged.  You will need at least 12 volts and maybe more to heat  properly. We see 13.2 + while attached to a running vehicle at the fridge supply screws. I hope someone else here can do a better explanation then I can. Sorry.
