Installing Domeq 3 way refrigerator.
ralphward388
I'm told I need a 1000 custom cabinet and ventilation system done to install a Domeq 3 way refrigerator in place of a 120v compressor type refrigerator.  Is this correct? It was going into a 2004 Scamp 13.
Ralph
ADDENDUM
Looked it up. Looks like a fairly simple bit of work to build cabinetry ventilation system for it. I will give it a try.
Venting to outside
You will need good venting to the out side for both heat rejection and Propane exhaust fumes when on LP. also proper sealed from fumes entering is important too.  Dometic sells the plastic side panels  But as my new 13 scamp is laid out it barely gets enough thermal heat transfer ( convection )  in hot weather very doable but not easy
ralphward388
Refeer install.
Thanks for the reply. I went ahead and had them do the install. After all, if there is some kind of leak that kills me I want to have someone to sue!
Ralph Ward
Scamp 13 Newbie
