What are Scampers using fo CO and propane detectors?
Clouds_Guy
Last seen: 8 years 2 weeks ago
Hi all,
What are folks using for carbon monoixide (CO) and propane detectors?
Where are you mounting them?
I assume fire extinguishers are also a must have.
Where is a good solid place to mount one so it will not get  shaken off while traveling?
Clouds Guy
We got our Scamp with a fire extinguisher mounted near the sink. Its a must have. CO detectors are to be mounted low, some 4 or so inches above the floor. I was also told that when using the heater, crack a window no matter the temps. I hope this was helpful.
Clouds_Guy
Tnx
Tnx for that info.
dr tom
dr tom's picture
Both are standard on new
Both are standard on new Scamps.
dr tom
