Pedestal table for 16' side dinette wobbles
TDLPEL
We are looking for a way to stabilize the pedestal table on the side dinette -- it's pretty wobbly. We still need to be able to turn it into a bed easily each night. Ideas? Also, do you leave it up when traveling or take it down?
The Sequoia table base really
The Sequoia table base really steadies things up. The floor base ring is only about 1/2" tall and can be recessed to make a level floor. The post then locks solid into the base. You still end up using a cone fitting for the table top fitting. If the post is too tall you can remove the post end (Drill out and replace several pop rivets,) and cut off the post. You can also order sequoia pieces from Amazon.
https://www.campingworld.com/sequoia-table-leg-system-74002.html?msclkid...
