shower
Rhalford
shower
after 2 coats of marine gloss white  good for fiberglass wood and steel of which i had to cover all 3  i hope the paint smell will go away
Rhalford
shower
thats the Rust-Oleum 207001 Marine Topside Paint, Oyster White, 1-Quart $12 a quart i used the cabot marine water sealer from lowes also $12 a quart i put 4 coats on all of my birch wood with 1 quart  the tankless water heater i found on line re-conditioned from the factory for $150 delivered to the house weighs maybe 5 lbs
Rhalford
shower
all of my walls after 4 coats of sealer
Rhalford
shower
2 of the 3 walls in place  ill screw them  in this weekend along with the 3rd wall and all the shelves   i hope to install the heater and hopefully  the shower heads and all the plumbing  still havent found #6 3 wire that isnt stiff to make a cord to plug the water heater in directly to the box at the campsites  the heater requires alot of juice to make water hot instantly  not sure if i want to go with a shower curtain for a door as planned or make a slider door out of something light   everything ive done so far weighs less than 100 lbs  i got rid of that or more with what i removed birch is very light those walls all together only weigh 60 lbs  more coming
Rhalford
shower
i  looked at what i posted sunday and somehow all of the pics got really big which is good  but when i looked at what i just posted the pics were small  any thoughts?
Last seen: 22 hours 39 min ago
The Editor Genie
The editor Genie edited your pics. surprise  You have to drop down the Style list and pick the size before you insert the pic in your post. Three sizes Medium is default, Large and Original. Just have to play with each size to figure out which one looks best. You can simply click on the picture in your post and hit your delete key then go reinsert it if you want to change size or position.
Rhalford
pics
thanks ill have my wife show me  for next time
EmilyEdith
My husband and I are in the midst of remodeling our 13 ft scamp right now and trying to figure out the logistics of adding a bathroom. Your post is awesome! After a few years how is your bathroom holding up? Am I right that you just painted right on the fiberglass and that gives you your waterproof walls? We were looking at waterproof wall panels but we are having a tough time trying to brainstorm a way for them to fit all the curves. Any other tips on adding the bathroom/shower?
Rhalford
fit
i made templets out of taped together empty beer carton cardboard   i made a million trips in and out of the camper before they were close enough  still had to use a good bit of caulk to make up some space  good luck
