Brand new to the Scamp world. How can I clean the inside?
Svick79
Last seen: 12 years 2 months ago
I am new to the Scamp world and have just gotten a "barn fresh" Scamp that is in need of a good cleaning for sure!  It has the mole skin (I think its called) fairly well intact but the tape is solid brown and the walls are solid mildew.
The inside looks like it has been pretty wet but the shell seems to be intact.
Can I Clorox the mess out of it and then paint it with Kills?  Or whats my best option?
I think it is a 77 (ish) model  Windows all seem to work as well.  Its been sitting a while but looks like I could clean it up.
** I have pics - but cant get them to come up....
Last seen: 5 days 13 hours ago
Elephant Hide Cleaning
You have a very easy liner to clean and refurbish to brand new look. It is referred to as Elephant Hide for obvious reasons and the later Scamps change to "Rat Fur." The hide is very easy to clean and then seal with Zinsser Perma-White. This is a mold and mildew sealing primer/paint that will bring your hide back to better than new and seal in anything. The previous owner was a lifetime smoker and after cleaning the hide with a nylon bristle brush and 409, then painting it with the Zinsser Perma-White it came out incredible on our 1981 13 and no one could ever tell there had been a smoker.
In this 1981 13 Scamp Rebuild video we made years ago, you'll see the transformation on the Elephant Hide.
I also got rid of the seam tape, which I personally never thought was a good finish. I then used silicone exterior paintable 50 year caulk and filled the seams even. After a bit of practice you can get the texture of the caulk to match the finish of the hide and when you paint it the seams almost completely disappear.
The nice thing with painting the hide is that if you accidentally scuff it or it gets dirty in a spot, you can simply touch it up when you get home. It is very durable and over the years we owned the trailer it never chipped or came off.
scamp refurbish
Wow! What a job pal. I checked out the video, and the rebuild. Nice work for sure! Oh the fun of scamps!
