Boneheaded move on my part
Sardith
So, I made the foolish mistake of running both D/C and propane power sources at the same time. I have since shut off the D/C, and am running propane alone,  but can anyone tell me what damage I may have caused by running both at once? Everything seems to be working fine, from what my novice eyes can see. Thanks!
Last seen: 6 hours 26 min ago
Fridge
It's probably fine if it's now working. A long term stall, either by two heat sources or off level operation, can cause a corrosion inhibitor in the coolant to crystallize and permanently clog the system.
