removing stains
Rhalford
removing stains
used this to clean my 13 ft with a few weeks ago. turned out great  went camping under a florida oak tree last weekend and it dripped stuff all over my roof that stained it like brown coffee  this cleaner wont even touch it   any suggestions
stain removers
Cleaners with oxcylic acid (sp) in it work great on stains. Boat hull cleaners like Y-10. A cheaper option is barkeepers friend which is very mildly abrasive. In most cases just placing the clearer on the stain will remove it. Apple cider vinegar is also used to remove oak tree stains.
Rhalford
barkeepers
you mean a clay bar ?
Barkeepers Friend
https://amzn.to/2uyHipj
I think Wal Mart sells it. I get mine from Ace Hwd.
Rhalford
thanks
thanks
Online
Last seen: 23 min 34 sec ago
3M Restorer
I use that as the first step of two step process. Use the 3M as a polish with orbital polisher and then you need to go over it with Meguiars Premium Marine wax. The Meguiars step most likely would have prevented the staining. Once the chalking is out with the 3M and polisher then you only need to apply the Meguiars going forward about twice a year.
Rhalford
wax
i used the wax also before this trip but it still made it through to the fiberglass   washed right off of anything that wasnt fiberglass
