Battery charging
AnthonyRM
Battery charging
If the camper is plugged into electric at a campsite, is the battery charging?
Last seen: 48 min 20 sec ago
Charging
Yes, if things are working as they're supposed to.
carl
Just make sure your converter
Just make sure your converter is plugged in.  They some times wiggle loose .
AnthonyRM
Converter location!
On the 13 footer, is the converter located under the bed/table on the right side, looking at the table?
Anthony Memoli
Last seen: 2 months 2 days ago
It is in that location on my
It is in that location on my 19-footer and the layouts are similar on all Scamps. It should be accessible by lifting the cushions and a cover. It is also a convenient storage for items used rarely. However, do not block the converter ventilation.
And, don't forget when
And, don't forget when boondocking to get a brief case solar panel to connect directly to your battery.
