Adding 12V DC circuits
whitegrays
Wondering how to access the rear of the Progressive Dynamics AC/DC panel to add a couple 12V circuits (for a 12V plug and to add a CO/LP detector).  Do I just remove the entire panel with the four screws on the frame and pull out the entire panel?  I'm asking because they are very tight and don't want to break something if there is an easier way.  Thanks
Last seen: 1 year 3 weeks ago
PD Converter
On the PD 35A converter I just installed the fused ckt. wires (black I think) just come out of the back of the converter. You can just splice into one of the output wires or use a terminal strip like I did. There is a DC common ground wire to connect your ground wires to behind the converter which is also your battery ground wire. I also used separate a terminal strip for the ground wires. YMMV
My converter is a PD4135KW2BV the distribution panel and electronics are all in one unit. It may not be the same as you have in your Scamp. Mine was a new install.
whitegrays
thanks!
thanks!
