Water entering in Back of Refig.
Bob Ivey
Has anyone had this problem or know how to stop water from entering the outside refig panel?  The panel is near the door on a 16 ft Scamp.  The water does not appear to come fro the roof area.  Thanks.
carl
Do you mean from the outside
Do you mean from the outside vents. To stop the water from coming in ,level your trailer ever so slightly to the right. And i used the smallest weather striping i could find and stuck it to the edge of the vent opening. That stopped the water from coming in so far.  Carl
viking65
Outside water leaking through outside frig. vent
I had a similar problem.  If you look in your owner's manual packet.  You will find a gasket that seals around the outside frig. vent.  I do not know why they did not install it at the factory.  Once I installed the gasket I did not have any more water problems.
