Check valve problem
SAM
Last seen: 7 years 1 week ago
Check valve problem
2011 Scamp city water connection check valve is leaking. Is there an easy fix
Last seen: 3 days 20 hours ago
Check valve
$15 new. And it is not a regulator as Scamp states in the description. It’s a common part, you should find it locally. https://www.scamptrailers.com/parts-store-cat-view/plumbing/city-water-i...
SAM
check valve
Thank you!
Mary Kelly
Last seen: 1 week 6 days ago
Dirt?
It could be just a little dirt or debris in there. From the outside take the screen out and inspect. Also you can push the check valve in with you finger which may help getting it to seat properly. Good luck!
