Air Conditioner Draining
kwombat
kwombat's picture
We completed our maiden voyage and even had an opportunity to use the air conditioner.  The first morning we noticed the ground was wer on the right back.  There was lots of condensation on the right side of the trailer.  Is this normal?  Exactly how does the water created by an air conditioner drain in the Scmp/  Seems like there should be a tube or something.
A/C Condensate Drain
The RV roof Air Conditioners simply drain onto the roof, consequently, you will get a wet spot underneath the lowest corner of the trailer.
This is why I do not set my trailer to perfectly level, I prefer the wet spot to be on the driver's side rear of the trailer. Of course it does not always work out that way, but, at least I have a preferred wet spot location.
Yes, the AC drains terribly
Yes, the AC drains terribly and wets the side windows as well.
