Mold
PA
Last seen: 11 years 3 weeks ago
Mold
I recently purchased a 13' SCAMP.  My first camper was a 6' x 8'  sleeper with no galley so I am new to having a shower, sink, AC,  etc.    I recently noticed a small amount of black mold starting on the permanent mattress in my SCAMP.  I'm in a panic about this for fear of it spreading to the wall covering, and hoping for suggestions.  My particular SCAMP is all electric.  Thanks ahead of time.
Boreggo
Boreggo's picture
Last seen: 10 years 8 months ago
Mold Remediation
Hi, PA-
Living in Florida, a dehumidifier is in order, or at least a couple of regularly monitored Damp-Rid buckets. Personally, I would get rid of any foam rubber with black mold as it is impossible to treat such a highly porous item. Plus, it is cheap and easy to replace compared to your health!
Once you have dehumidified, try a couple mold bombs; let dry and vacuum thoroughly using a vac with a HEPA filter; follow up with a biocide spray and HEPA vac when dry. See this combo available on Amazon:Biocide 100 Mold Fogger Pro Clean Bundle . Remove the curtains and launder in hot water with your usual detergent and a hefty scoop of OxyClean.
I would then follow up by cleaning all the surfaces in the unit using this product as a spray Concrobium Mold Control Household Cleaners, 1 Gallon   then wiping up after a minute. Run the dehumidifier or use Damp-Rid there after.
Good Luck and stay healthy!
Bernie
Bernie & Bob,
Newbies needing Mentor(s)
1984 19' 5er PROJECT "Boreggo"
1999 Dodge Ram 4x4 2500 "Thunder Buggy"
Tallahassee, Florida & Poway/Rancho Bernardo, California
Lis
Lis's picture
Good site to learn about mold
All you want to know about mold and how to get rid of it  http://www.concrobium.com/en-can/all-about-mold/  .
Good luck,
Lis
Lis in RI
