Great LED Light Bar -- Replace Flourescent
I found a GREAT LED light bar for use around the camper.
This light is very well built and it has very good brightness it would be perfect for lighting the cabin or for use as under cabinet lighting it would even be great for use as a replacement for florescent lights.
It comes in a "warm" white and a "cool" white version, I chose the "Warm" white and the light has a very pleasant yellow hue. It also has a very sturdy in-line switch.
These lights operate off of 5v USB power so you will need either a 12v USB adapter or you could operate this off of a USB battery pack.
This light would be an excellent choice for reducing your battery usage during boon docking.
LED Light bar
LED Light Bar Paired With a USB Battery Pack
I purchased a USB Battery pack for use with this light bar. It operates the light for eight hours plus. This makes for a nice, lightweight,  portable light that I can use anywhere. I have attached Velcro to the back so I can move it around to wherever I need it ( I can also use this for working on the Camper or Tow Vehicle.).
Here is the USB Battery Pack I purchased:
PS: This USB Battery pack is well built and compact.
