adding shower part 4
Rhalford
Last seen: 9 months 4 weeks ago
   this is the cord i made  was able to use the factory hole in the front of the scamp
Rhalford
    the hole i drilled for the water line and a couple pics of the water heater and the line running to the shower head
Rhalford
adding a shower part 4
   i put a shut off in the supply line ran it acrossed to the same side that the other water hook up is on and put a garden hose female hook up for easy connection at the campground
Rhalford
     a pic of the hand held shower head i put an on off adaptor at the head for saving water   the drain was a sink drain from lowes for $12    the shower curtain rods are made out of pcvp pipe and fittings    chose to put a  curtain acrossed the back to keep the toilet area dry and i put the 12 volt light in its original place  no sense running water on a light fixture even though it is only 12 volt   purchased plastic rings and a shower liner at target for a total of $5 this weekend   already have my harley knobs just need to find my cabinet doors  then make a door for the shower  pics of the doors coming for the final installment and the project will be complete
boler71
boler71's picture
Hi there!  I like how you did
Hi there!  I like how you did your shower, I am restoring a 1971 Boler (just joined this forum) and adding a front bath.  I turned the front bunks 90 degrees to where the original kitchenette was and they will also convert to a couch so the toilet is on the door side of the shower.  I came up with this idea right after we bought our Boler home 3 months ago and just last night I happened to be on the ParkLiner website and seen that they actually design their trailers exactly like what I had in mind except they made their bunk also turn into a side dinette.  So I am adjusting my design of the bunk/couch to also serve as a dinette too.  For the shower pan we opted to use a utility sink so it will be multi purpose (sink for washing hands/dishes, a shower and also a tub for our 2 year old.  I am making the floor under the shower pan removeable so when we are at camp I can lower the shower 4 inches with custom built platform that will sit on the ground so I have 4" extra head room (I am 5'9' and standing in the shower my head is right at the ceiling.)  We are also using a propane instant water heater which will be mounted on the wall beside the porta pottie toilet and vented out the roof.
