Dometic Refrigerator Parts
LGB101
We think the Dometic 2.0 CRX65 refrigerator (only 1 year old) in my 2023 13 standard Scamp needs either a new thermistor or circuit board.  It runs occasionally then shuts off and so on and so on.  The compressor light turns orange, as does the service light.  It doesn't run long enough to keep anything cold.  I've watched videos on how to replace both of these parts but I cannot find any parts.  Dometic's website is no help.  Scamp doesn't know what's going on with it either.  Does anyone have an online source?  It is still under warranty however a diagnosis fee that I will have to pay the repair shop is $154/HR.  If it's a simple fix I would rather save the money and do it myself.  Thank you for any input!
Peregrine
Last seen: 2 weeks 5 days ago
Dometic refrigerator RM2354
Should this fridge model work without a functional converter? That is, will it ignite using power from the battery? When the power button is pushed, all the panel lights flash, but it doesn't seem to light. The lights continue to flash for minutes. I have pushed the power on and off several times. The stove lights, so gas is available. We will be troubleshooting the converter- need to purchase a voltmeter! Thanks for any advice-- I'm technically challenged.
Peregrine
The converter checked out OK. Checked all fuses. Indicator lights are still flashing. Read somewhere that the flashing pattern is a clue to trouble. Does anyone know about this? Again, any responses are appreciated.
Last seen: 1 day 12 hours ago
RM2354
Here is a good reference list for the manuals and operating instructions. https://techsupport.pdxrvwholesale.com/technical-service-manuals/dometic-rm2354/  You should be getting clean lights with gas selection illuminated so the flashing is something going on for sure.
Maybe, this will help as it seems to be what you're experiencing.
https://www.forestriverforums.com/forums/f113/dometic-model-rm2354-lights-on-panel-flash-clicking-noise-not-burner-trying-to-light-185309.html
