Drain path from sink to outside
telluride1997
For a year of so I have been using my parked Scamp regularly, that is, making use of the lights, stove, and sink on a constant basis, with external water and electric supply.
What is the exact path of the water from the sink to outside?  Is there a flow diagram of this 'path' available. I will try to trace that very soon.
My problem is that while the water into the sink is clear, the effluent from the plastic pipe on the back left is a brownish-yellowish color. I do not detect an odor. So it seems obvious that I need to clean out some pipes and/or vessels, but I do not know where the likely problem is, nor how to best clean it.
Advice on this matter would be much appreciated. Thanks.
Last seen: 10 months 3 days ago
Sink trap and drain
This is the latest version of the sink trap and drain Scamp has used for years for the kitchen sink. Amazon.com: Camco Flexible Camper Drain Tap with Hose System for RVs Campers and Trailers, Easy Connection and Set Up (37420) : Automotive In the past Scamp has used a piece of water hose or clear plastic tubing as a drain hose. The Clear tubing will develop mold in the hose which will be visible. I'm sure the trap also has it's own culture growing. Give it a shot of bleach if it makes you feel better, It's just greywater. If you have a greywater tank no telling what is growing in the tank.
Last seen: 2 days 23 hours ago
"Dosing" Fresh Water Tank
At least once each season I "dose" our fresh water tank with bleach. 1 cup of bleach for the 12 gallons of water. After a day or two I drain the bleach and water solution into a bucket and pour it into the sink. That way I am also "dosing" the sink trap, drain piping and the gray water tank. After a few days in the gray water tank I drain the bleach and water out and discard. Our sink trap and gray water tank seem to be fairly clean with no odors.
